High rpm around 4,000 while doing 55-60 mph
2001 VOLKSWAGEN JETTA
173,632 MILES • 4 CYL • 2WD • AUTOMATIC
MOUSE357
  • 58 POSTS
What would keep the transmission from shifting gears? Please help.
Jul 5, 2020 at 5:24 AM
There are a number of things that can cause this. However, we need to start with if there are any other shifting issues? Are there any codes?
The most likely cause would be the torque converter is not engaging so I imagine there should be some codes confirming this.
I believe the vehicle has an OD button. Let's just make sure that button is not pressed turning off OD or it is not flashing.
Let me know what you find and we can go from there.
Thanks
Jul 5, 2020 at 11:42 AM
