high idle and is jumpy when in gear.
2001 SATURN SL1
153,000 MILES • 1.9L • 4 CYL • FWD • MANUAL
CUTHROAT3
When my car is driving down the road and I push the clutch in to shift gears, the RPMs stay where they are and then go down really slow. It started to feel a little jumpy in third gear around 3000 RPMs. It felt as if I was tapping on the breaks and accelerator at the same time. Now it does it in 2nd, 3rd, and 5th gear and seems to be getting worse. Had it coded and they said it was an O2 sender. New plugs and the guy who had it before me said he had just replaced the intake gasket because of a high idle. Need help as this is my only car.
Jul 24, 2014 at 7:12 AM
FREEMBA
  • 1,152 POSTS
Please post the exact code number that you got. This will help me to send you the correct info. There are several O2 sensor codes. If you no longer have the code, have the computer scanned again and write down the code so that you can post it here.
Thanks.
Jul 24, 2014 at 8:48 AM
CUTHROAT3
The codes are P0326, P1133, and P0133
Jul 24, 2014 at 11:16 AM
FREEMBA
  • 1,152 POSTS
P0326 = Knock Sensor System Performance
P1133 = O2S1 (Oxygen Sensor #1) circuit - Insufficient switching
P0133 = O2S1 Circuit - Slow Response
The knock sensor code could be caused by low octane fuel, a loose engine bracket, tapping valve lifters, etc. (Something on the engine causing a tapping/knocking noise).
The two O2S1 codes could be caused by the O2 sensor being contaminated by engine oil, coolant or RTV sealer (used when replacing valve cover gaskets and other gaskets).
Jul 26, 2014 at 6:28 AM
CUTHROAT3
what do you suggest I do
Jul 26, 2014 at 6:48 AM
FREEMBA
  • 1,152 POSTS
For CODES P1133 & P0133: Check Oxygen sensor #1 to see if you have 5v on the purple wire running to it. The sensor is located on the left side of the engine on the exhaust manifold. If you do have 5v on that wire, replace the oxygen sensor (the circuit is functioning properly and therefore the problem is in the sensor).
By the way you should repair any problem that may cause the oxygen sensor to become contaminated; such as the engine burning oil [indicated by a blue smoke from the exhaust pipe], the excessive use of RTV sealant (used when replacing gaskets), or engine coolant getting into the cylinder.
For CODE P0326: Replace the knock sensor which is located on the right side of the engine near the starter.
Jul 27, 2014 at 12:27 PM
CUTHROAT3
can one or both of these cause the engine to run high idle when I push in on the clutch?
Jul 27, 2014 at 8:33 PM
FREEMBA
  • 1,152 POSTS
Yes it is possible. Also, you should clean the throttle body and Idle Air control (IAC) solenoid using spray type throttle cleaner. Here's how:
1. Remove the air snorkel which runs from the air filter box tot he intake manifold.
2. Have a partner to hold the throttle to the floor (engine OFF).
3. Spray the cleaner into the throttle opening and use a cloth and/or small soft bristle brush to clean the throttle plate and the entire opening.
4. Remove the IAC solenoid (be careful not to lose the rubber O-ring which goes around it - this is a seal and the engine will run terribly without it) and clean its tip with the throttle cleaner.
5. Clean the bore that the IAC fits in to as well.
6. Have your partner to release the throttle.
7. Replace the IAC, air snorkle and any hoses or wires removed during this process.
8. Start engine
**NOTE** the engine will take longer than normal to start because of the "floor" condition caused by the throttle cleaner. Once the engine starts, rev it a few times to burn off the excess fuel/throttle cleaner.
Jul 28, 2014 at 7:15 AM
