High idle at first start
1999 CADILLAC DEVILLE
157,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MROULET1
  • 79 POSTS
Every time I start my in the morning the RPMs start at 1,000 go up and down then it will slowly start getting higher and higher almost 2,000 sometimes. feels like if I’m pressing the gas and when I put it in a gear it slams because it’s already accelerating. then car will then pretty much accelerate on its own. I will do all kinds of stuff like shut the car on and off sometimes that works. I’ve done changed out da IAC and the TPS and it’s still doing the same stuff. I really need someone help.
Dec 12, 2021 at 10:53 AM
  • 110,236 POSTS
If you have already replaced the IAC, you may simply have an engine vacuum leak. Allowing unmetered air into the engine can play havoc with the idle speed.
By chance, do you have a live data scan tool? If you do, can you let me know what the short-term fuel trims are when this is happening?
Take a look through this link. It explains the most common causes of a high idle. One thing covered is the IAC, but just bypass it and move to the next topic.
https://www.2carpros.com/articles/engine-idles-too-high
Let me know if that helps or if you have other questions.
Dec 12, 2021 at 1:25 PM
