High co emission at high idle
87,000 MILES • 2.0L • 6 CYL • FWD • MANUAL
ROLYY17
  • 5 POSTS
Hello There
My Chevrolet epica is faild on NCT ON high idle Only
2 Months ago its faild on Lambda and very high CO it was 1.98 VOL 0.20 The limit i changed the lambda,air oil filters new oil than took it into a garage check emission the guy said its jmping between 0.10 and 0.40 it could be a dirty throttle body or bud temperature sensor....i checkd the throttle body it was dead clean and replaced the temperature sensor than took it to NCT again/It FAILD on HIGH CO on High idle 0.32...the guy said he cant get it past because it wont stay long enough under the limit its jumping......so my question is what possible cause this problem(i have to mention it HC CO2 O2 everything very low) and one more thing my air fuel ratio is 9.76:1 i think its runing rich shouldby 14.7 isnt it?
And i think my thermostat not working properly because its stay down very long and when its heats up drups down a bit than up again is this cuold be related to running rich? and i have a bit rough idle when the engine cold or warm...otherwise driving well
so any help would be great
Thank you
Nov 23, 2013 at 10:30 AM
  • 110,251 POSTS
If the engine isn't properly warming up, it will cause the engine to run rich and raise the emissions. The engine should idle around 200 degrees F. Is it getting to that point?
Nov 23, 2013 at 12:52 PM
ROLYY17
  • 5 POSTS
Hi
Yes even if i drive longway still running rich....when i taking the spark plugs out all black and wet a little bit
Nov 23, 2013 at 5:37 PM
ROLYY17
  • 5 POSTS
I just looked the result of my last night test after when the temp gauge richt half waf it mesaured 180 degrees F then it dropd down to 150 than started go up again slowly.....i hope this is some help
Thx
Nov 23, 2013 at 5:45 PM
  • 110,251 POSTS
It sounds like you have a bad thermostat and it isn't getting hot enough.
Nov 24, 2013 at 3:51 AM
ROLYY17
  • 5 POSTS
I gonna replace it and will see...ill post the result
Thx for your help
Nov 24, 2013 at 6:52 AM
ROLYY17
  • 5 POSTS
Hi again
Its failed on high co still the car hot enough now i did change the thermostat but I am getting the same result...any idea
Thx
Dec 5, 2013 at 9:32 PM
