high and low beams quit working
2008 CHEVROLET EQUINOX
168,000 MILES
JOEDMARTIN
High beams quit workin and two weeks later low beams quit ive replaced the dimmer switch in sterring column and checked all the fuses and still cant get them to come on
Dec 26, 2015 at 7:05 AM
JOHNNYT73
  • CERTIFIED EXPERT
  • 924 POSTS
Check your relay in the fuse block under the hood. Swap it with the horn relay if it is the same to see if that works.
Dec 26, 2015 at 7:20 AM
