Starts fine, idles fine. When you put the car in gear idles fine. When you push the gas it jerks and shuts off. It does not matter what gear. No check engine light. Changed four O2 sensors, fuel filter, oil and filter, spark plug and wires, and lock out sensor for the transmission. Shifts into gear fine. What else could be wrong? Mechanic we took it to was unsure.
Jun 21, 2018 at 4:58 AM
