Accidentally started truck after dropping small socket in spark plug hole
187,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
REGINA PUCHALSKI
I dropped a small socket in my spark plug hole and accidentally started it what could have to it or gone?
Jun 30, 2019 at 10:00 AM
  • 110,248 POSTS
Welcome to 2CarPros.
I can't imagine that it is going to get past the valves and into the exhaust, so I suspect it is still sitting on the piston. When it was started, was there a lot of noise? Have you tried getting it with a magnet?
They make a scope camera that is used to get into small places for inspection. You may want to contact a local parts store and see if they have one to rent. That way you can see where it is and if any damage was done.
Let me know if I can help.
Jun 30, 2019 at 12:16 PM
REGINA PUCHALSKI
Thank you for getting back at me. When I started it it just made like a little rattle like sound I made a home made magnet. And finally got two pieces out I guess I broke the socket when I started it up.
Jun 30, 2019 at 12:21 PM
  • 110,248 POSTS
Welcome back:
Wow, you are lucky it didn't break a piston or valve. Honestly, if it broke, chances are the small pieces are in the exhaust somewhere. However, I really suggest getting a scope and checking to make sure nothing is lodged in there.
Jun 30, 2019 at 1:01 PM
