Engine light is on
160,000 MILES • 6 CYL • 2WD
FRANK KEMPSTER
Hello guys, my engine light is on and the temperature remains low on the dash light. Says engine hot. There is no sign of leaking and the cold reservoir remains full. The air blowing in seems cooler than normal. What do you think? Thermostat not operating? Thank you, Frank.
Apr 4, 2018 at 3:28 AM
SATURNTECH9
  • 30,869 POSTS
If you could scan the car for codes that would tell us a lot like if you had a code p0128 you would have a bad thermostat.
Apr 4, 2018 at 12:32 PM
SATURNTECH9
  • 30,869 POSTS
FRANK KEMPSTER
Thanks guys, I will replace that thermostat.
Take care, Frank
Apr 8, 2018 at 12:44 AM
SATURNTECH9
  • 30,869 POSTS
Did you end up having a p0128 code?
Apr 8, 2018 at 2:36 PM
FRANK KEMPSTER
Good morning, I replaced the thermostat and reset the codes by disconnecting the battery.
Everything is good.
Thank you again for the help
Frank
Apr 8, 2018 at 11:26 PM
  • 55,554 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Apr 11, 2018 at 2:14 AM
FRANK KEMPSTER
Thank you again Ken, I have got a bunch of traveling to do in the next few months.
Take care, Frank
Apr 19, 2018 at 8:48 PM
