Just bought a 1998 Lincoln and found the heater blows cold when set the temperature to heat also the air conditioning compressor is on and working when my climate control is set on 80-90 degrees, if the blend door is bad would that be the reason that the air conditioning compress is on when i switch to the heat mode
Oct 21, 2013 at 1:54 PM
