Heater
217,000 MILES • 3.0L • 6 CYL • TURBO • 4WD • AUTOMATIC
JAMES SANDWICH
Heater not hot on passenger side.
Jan 5, 2018 at 2:08 PM
KHLOW2008
  • 41,812 POSTS
Hi James,
If one side is working and the other is not, it indicates a fault with the air mix control. Usually it is a faulty air mix control motor that is causing this but sometimes it is just a linkage that is dislodged. The motor is under dash attached to the heater housing.
Jan 5, 2018 at 4:29 PM
