Heater not working
2009 DODGE CHALLENGER
114,476 MILES • 6 CYL • 2WD • AUTOMATIC
TALITHA WIGGINS
It is suggested that i replace the PCD harness. Where can I buy this and how do I know the right one to buy?
Mar 16, 2022 at 2:38 AM
  • 110,241 POSTS
I'm not sure what you are referring to as PCD. Could you mean PCM, PDC, or something different?
As far as the heater, what is happening? In most cases, if it isn't a coolant level or flow issue, it's the blend air door actuators.
Let me know as much as you can as to what is happening, when you first noticed a problem, were there any indicators prior to it not working?
I will watch for your reply. In the interim, take a look through this link. It reviews the most common causes of a no heat condition.
https://www.2carpros.com/articles/car-heater-not-working
Mar 16, 2022 at 9:31 AM
