Headlights have never worked properly
110,000 MILES • 5 CYL • 4WD • AUTOMATIC
ROVANTON
  • 6 POSTS
When the headlights are on they shine straight out instead of fanning out so you can see a few feet on each side of the road. They are not any better on bright than they are on dim. They shine as if you are in a tunnel. In other words they shine directly out in front of you but not to either side. When you turn a corner it blocks even more of your view. I bought replacement bulbs that were suppose to shine farther out thinking that might help but it did not make any difference. I have taken it to the dealership and had them adjusted but they told me there is nothing they can do to make the lights shine out wider. The way they are now, it as if your peripheral vision is totally blocked. Please help. Thanks.
Feb 1, 2018 at 3:47 AM
  • 55,743 POSTS
It would have to be aftermarket headlight lenses on the truck. These lenses are constructed in a specific way which it sounds like the aftermarkets have missed. The only other thing that affects the bean is bulb placement in the lens.
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Feb 2, 2018 at 5:40 AM
ROVANTON
  • 6 POSTS
Thanks Ken, I bought this truck new and the headlights have never worked properly. I will try to take a video and send it to you. Thanks. again, Larry.
Feb 2, 2018 at 7:13 AM
  • 55,743 POSTS
A video would be great!
Feb 3, 2018 at 2:09 AM
