milky brown gunk in cooling system
90,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JOECUS
I have milky brown gunk in my cooling system. I do not have coolant in oil. I removed all spark plugs and did a compression test, all were fine at 150 psi. I did notice some oil on one of the tips of plugs. The car did overheat once due to a leaky hose. I am original owner. Does good compression mean head gasket okay? I did not do pressurized coolant test or the gas test kit. Can throttle system cause this? What is the best way to proceed to see if it is blown gasket? thank you very much.
Feb 7, 2018 at 6:10 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If you have an automatic transmission that has an oil cooler inside the radiator, make sure you pull the transmission dipstick and make sure it is not a blown oil cooler, because that will mix coolant with transmission fluid.
It all depends on the two colors for which color it would change to but since you said the engine appears okay, I figured I would tell you that.
Plus, a head gasket can blown in many spots, one being in between the coolant and oil passage in the gasket without either being blown to the cylinder and pass a compression test.
Feb 7, 2018 at 6:22 AM
JOECUS
Thank you. Yes the car runs total fine. No over heating, no smoke, no engine miss. I am going to take radiator out and see if it has an internal leak after I look at dipstick. Also, it is an aftermarket radiator I put in a few years ago. Maybe they are mixing there. Let me know if you disagree with my plan of action.
Feb 7, 2018 at 4:33 PM
JOECUS
The one thing that bothers me is I found oil in one on the spark plug in one of the cylinders. Compression was fine. any thoughts?
Feb 7, 2018 at 4:37 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Then the oil is probably coming in from either a bad valve guide seal or a stuck piston oil control ring, the bottom rings, not the compression rings. Sometimes, those oil control rings can get stuck from carbon buildup and not expand anymore to scrap the oil off of the cylinder wall and thus the extra oil getting into the combustion chamber.
You can try to unstick and free up that carbon by trying some Gunk Motor Flush added into the motor oil when cold, then start and idle the engine for five to ten minutes, allow the cleaner to work its magic of cleaning out the carbon in and around those oil control rings and bring life back into the oil control. then drain the oil, empty the filter and add some new motor oil and check the spark plug after some time to see if it worked. And remember to keep up on the scheduled oil changes and do not run without a thermostat for too long cause this causes the engine to take too long to warm up, the piston and rings not to expand and properly seal, thus gas blowby into the oil pan diluting the oil, thus causing problems with carbon and gunk buildup because of the lack of motor oil protection.
Now, back to the oil cooler in the radiator, you can check that while still in the vehicle. Disconnect the transmission lines and use air pressure in one cooler port and cover the other one up and see if both it holds pressure and no air bubbles coming up in radiator coolant. I just would not go too high on the air pressure, maybe 15 psi or so.
But if you do have that same funky fluid in the transmission and on its dipstick, that is the only place it can mix is inside that radiator and a busted oil cooler.
Feb 7, 2018 at 9:35 PM
