Hazard lights flash after locking vechile only sometimes
2007 HOLDEN BARINA
108,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
JAS1979
I own a 2007 Holden Barina TK7 1.6 litre auto hatch.
I currently have a problem whereby sometimes after the vehicle is locked and the indicator lights have flashed to signify the car is locked (as they should), some time later the indicator lights will flash intermitently at random for around 30 seconds and then turn themselves off.
In other words they malfunction.
This seems to occur about once every 2 or 3 days when the vehicle is parked. The vehicle is stock standard and has had no modifications done to it.
I either see this happen or people inform me that the car lights are flashing.
Can you please help me fix the problem?
May 26, 2015 at 6:58 PM
  • CERTIFIED EXPERT
  • 31,937 POSTS
You will have to go get a scan and see if there is a problem in the body control module, let me know if there are any fault codes and advise what the codes numbers are.
May 27, 2015 at 1:02 AM
