Hard starting and when the gas pedal is released, the engine shuts off immediately
120,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
JEEPT_T
While attempting to start the engine, I need to press the gas pedal for it to start. Then when the gas pedal is released, the engine shuts off immediately.
Jun 20, 2019 at 10:26 PM
  • 110,251 POSTS
Welcome to 2CarPros.
First, please understand this vehicle isn't offered in the US so I have little to no technical information, but I will do my best to direct you. Understand that with a fuel injected engine, when you press the throttle when starting, it shuts the injectors off. So, since it starts like that, I first suspect there is a problem with the fuel pressure. The first thing I recommend checking is fuel pressure and the fuel pressure regulator. Here is a link that explains how in general it is done. I have a feeling you will find the pressure to be too high.
Do this and let me know what you find.
Jun 23, 2019 at 3:23 PM
