Electrical issue
80,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
OMAR AL-AYASS
I have issue that when the car is on the cruise and ETCS and air bag works and the screen starts reset and air conditioner giving check the air conditioner connection and when I press brake all these lamps turns off and traction lamp turns on, and even the car gets smooth. when I press brake and the ABS lamp always on , I went to several shops and no one figure out the problem.
Oct 20, 2016 at 2:03 AM
HMAC300
  • 48,601 POSTS
it has to do it while a mechanic looks at it. However try cleaning the body to battery ground and engine to battery ground as it sounds more like a ground issue. it may be picked up by a mechanic's scanner though if it is doing it when you take it there.
Oct 20, 2016 at 2:39 AM
OMAR AL-AYASS
I checked the car by computer and it gives that and issue and one shop informed me that there is short in the car electrical, but I am afraid as no one is knowing the exact issue.
Oct 20, 2016 at 2:50 AM
HMAC300
  • 48,601 POSTS
if there is a short in vehicle it has to be physically checked to find out where it is. so it will have to have a mechanic try to find it.
Oct 20, 2016 at 5:30 AM
OMAR AL-AYASS
Some shops informed that this issue from the abs but today i haved a look under the steering and I found some cables have been cutted and wired again but without tape and one electrical informed me to put tabe on each cable and hope the issue will be solved and same i did and will wait few days to see
Oct 20, 2016 at 10:32 AM
  • 55,562 POSTS
Please let us know what you find so it will help others.
Best, Ken
Oct 24, 2016 at 12:01 PM
OMAR AL-AYASS
Off course once I solve the issue I'll update you
Oct 28, 2016 at 7:52 AM
  • 55,562 POSTS
Hey,
Did you ever get the problem fixed?
Best, Ken
Dec 21, 2016 at 10:09 AM
