Grinding or screeching noise at stop in reverse
1999 CHEVROLET LUMINA
164,534 MILES • 3.1L • V6 • 2WD • AUTOMATIC
MELCRY1107
It makes a grinding noise when in reverse as you are stopping and the lights dim for a second, also did it once in drive (sounds like when the starter hits the flywheel noise).
Any help ?
Apr 26, 2019 at 11:48 AM
  • 110,244 POSTS
Welcome to 2CarPros.
If the lights are dimming, it sounds like the alternator belt is loose and squealing allowing the alternator to slow enough to dim the lights.
Check the condition of the serpentine belt. Make sure it is tight.
Take a look through these links and let me know what you find.
https://www.2carpros.com/articles/car-squeaking-noise
https://www.2carpros.com/articles/how-a-serpentine-belt-tensioner-works
https://www.2carpros.com/articles/how-a-serpentine-belt-works
Let me know what you find.
Apr 26, 2019 at 1:32 PM
