Grinding noise/sensation
2010 FORD F-150
66,000 MILES • 6.2L • V8 • 4WD • AUTOMATIC
TYLER HUBLER
My truck is the Raptor model.
Okay this is sort of hard to explain but here goes:
I live in a very hilly area, think back country mountain roads with long straight stretches. When cruising about thirty to sixty mph, on a flat road everything is fine. But when the elevation changes, and I hit the bottom of a hill and start to go back up in elevation (when suspension becomes slightly compressed, more weight is being applied) there is a grinding noise/sensation that is felt throughout the vehicle.
It also occurs when coasting down a hill at just about any speed, both in drive and in neutral. Applying brakes makes no difference, but I have noticed a slight vibration in the steering wheel when applying the brakes as well, not sure if this is related or not. Braking is otherwise fine during all other driving conditions.
I have replaced both front wheel bearing hub assemblies and IWE's.
May 30, 2017 at 2:04 AM
HMAC300
  • 48,601 POSTS
there is a TSB on driveshaft for that but it has a build date before 1/26/12 and you have to look for separation on center support. see picture, it may not be it but it can throw a vibration like a bad u joint.
May 30, 2017 at 2:44 AM
TYLER HUBLER
Thanks HMAC, it is more of a rubbing noise than a vibration. Almost like a tire rubbing, but I see no signs of wear anywhere near the tires, does not really seem like metal on metal but very well could be.
May 30, 2017 at 3:09 AM
HMAC300
  • 48,601 POSTS
well it is hard for us to try to diagnose a problem like that. check dust shields hitting rotor or an engine shield rubbing against motor drive line. also, check by axle for something rubbing.
May 30, 2017 at 4:58 AM
