Grinding Noise from MT6
180,000 MILES • 3.5L • 6 CYL • RWD • MANUAL
AN LAM
Thanks generously sharing you mechanical knowledge. I have learned many things from your articles.
On cold start ups when i place it in either first or reverse gear and slow lift the clutch peddle, i hear a grind noise. After a few minutes, it goes a way. I have also noticed that if i let it warm up for a few minutes after a cold startup it does not produce the noise. This is the original clutch. Do you having any idea what could be the problem?
Thanks,
Andy
Mar 2, 2017 at 11:16 PM
KHLOW2008
  • 41,812 POSTS
Depends on where the noise is coming from and what is causing it. Noise are very dificult to diagnose over the net and sometimes even when vehicle is present , it is not easy to pin ponit the source. You need to perform indepth diagnosis to locate the source to understand what could be the cause.
Mar 4, 2017 at 6:20 PM
