Hi and thanks for using 2carpros.com.
First, make sure you have replaced the wires to the correct cylinders. I attached a picture of the coil and the firing order. Make sure each wire from the coil is going to the correct cylinder.
Also, make sure the connectors are secure at the coil and nothing is loose or any of the pins in the plug are damaged.
If everything is good, check to see if there is spark to the plugs. Here is a link that shows how it is done:
Last, if there is spark and the ignition wires are correct, see if the engine will start for a couple seconds using starting fluid. If it does, then we have a fuel related issue.
Images (Click to enlarge)
Dec 13, 2018 at 9:08 PM
