Radio issue 93 gmc 5.7 L 4x4, 210000miles
2012 GMC YUKON
TLGEIRNA
Having problems with radio in my 93 gmc suburban. It has a am/fm stereo with cassette and graphic equalizer which is all factory equipment. With key in accessory position, or on position before and after the start of truck the radio will light up and has power, but I am unable to change stations move the volume control up or down. There is also no sound produced by the radio. The radio has the ability to be turned on and off and clock comes on after station is displayed but it does not advance. Could this be and issue with a relay?? or do you think it could be that the radio is wearing out and needs replaced?? I have checked all fuses and they are in working order. I have also changed the ignition switch thinking that the contacts within the switch may have gone bad but it still does the same thing after replacement. Any help would be great!! Getting tired of the silence.
Nov 29, 2007 at 1:39 AM
CARADIODOC
  • 34,381 POSTS
It's been over two years. Sorry, but I just found this post. Have you found a solution? It sounds like you have a remote amp that isn't turning on. A quick test is to plug in a different radio from a salvage yard. Unlike Chrysler systems, Ford and GM radios must be selected according to whether or not they use the remote amplifiers so be sure to find the right model.
The selfish bigwigs at GM and Ford have decided to refuse to allow us to buy parts and service manuals for their audio products. For this reason, radios from those brands must be sent to their repair facilities. It is much less expensive to just buy replacement radios from the salvage yard. If you have the same problem, suspect a problem in the wiring to a remote amp or the relay you mentioned.
caradiodoc
Feb 27, 2010 at 5:21 PM
