Will the service engine soon light go off on its on after repair?
Monday, November 8th, 2010 AT 9:06 AM
JDL
MECHANIC
After the repair, you erase codes, either using a scanner or code reader, you can also remove voltage to pcm for 30 seconds. If the code comes back, the repair may not have been successful?
