1991 GMC Truck well i think its the trans
1991 GMC TRUCK
107,500 MILES • 6 CYL • 2WD • AUTOMATIC
B_COULMAN1
ok so my truck usually runs great..but once in a great moon while i am in reverse, my can just dies and the engine light, brake lights, all the lights come on and i dont kno wht hapened. but then it will start back up until anyway from 3weeks to 2 months then it will happen again. so if you have any idea what is going on lease let me kno. thanks
worried driver
Apr 17, 2009 at 8:39 AM
MICKEY-D
  • CERTIFIED EXPERT
  • 304 POSTS
I don't think your trans is the problem, I think it's a coincidence. Check your through the firewall wire harness for loose, or corroded connections. It would also be a good idea to check all the grounds to the engine and firewall. Hope this info helps..............Mickey-d
Jan 6, 2010 at 2:58 PM
