1988 GMC Truck Any connection between Transmission problem
1988 GMC TRUCK
131,000 MILES • V8 • 2WD • AUTOMATIC
PJKUBAT
Recently had the transmission reconstructed and I have gotten put back into my truck. Then the alternator didn't work, but it was original so I didn't question it and got it rebuilt. But then to test the transmission, I backed it out of the garage and found that now the brakes don't seem to work. Plus the engine won't idle down (which may be why the brakes aren't working right?). They look like original, but that's hard to believe and I wasn't having any problem with them before reworking the transmission. Is there something I should look at before going to the cost/time of replacing the brakes?
May 15, 2009 at 7:27 PM
DR LOOT
  • CAR REPAIR CONTRIBUTOR
  • 2,311 POSTS
it sounds like the shops may have accidentally knocked off the vacuum line that is why the Idle won't go down and you have no brake booster assistance, check all of your vacuum lines make sure they are connected and not creaked or kinked.
May 17, 2009 at 8:11 PM
PJKUBAT
Thank you. We DID find that problem the next day, so you were right on.
May 24, 2009 at 3:58 PM
DR LOOT
  • 2,311 POSTS
I apologize it took so long to respond, I may have saved you a lot of time.
May 24, 2009 at 4:06 PM
