2000 GMC Sonoma Secondary Air and Misfire Fix
LMM66
i have a 2000 gmc sonoma 4x4 4.3 v6. the check engine light came on. i read the codes saying - secondary air injection malf and cyl #2 misfire detected. i replaced the plugs and wires, and the light went away for about 500 mi and then came back with the same problem. what is secondary air? are these 2 problems related? the truck is getting very poor gas mileage.
Aug 16, 2007 at 7:55 PM
  • 75,988 POSTS
[quote:3c1bed742c="lmm66"]i have a 2000 gmc sonoma 4x4 4.3 v6. the check engine light came on. i read the codes saying - secondary air injection malf and cyl #2 misfire detected. i replaced the plugs and wires, and the light went away for about 500 mi and then came back with the same problem. what is secondary air? are these 2 problems related? the truck is getting very poor gas mileage.[/quote:3c1bed742c]
P0410 secondary air injection malf
what is secondary air- it is from the air pump to help oxidizes the exhaust gases so that the catalytic converter operates efficiently.
P0302 No.2 misfire could come from a weak coil/lean mixture/dirty injectors/vacuum leaks/burn exhaust valve/bad gas/low fuel pressure/Open EGR
Aug 16, 2007 at 9:15 PM
Suggested Repair
After plugs and wires, diagnose the P0410 secondary air injection system (air pump that supplies air to oxidize exhaust so the catalytic converter works efficiently) and the P0302 cylinder 2 misfire. Check for a weak coil, lean mixture, dirty injectors, vacuum leaks, a burned exhaust valve, bad fuel, low fuel pressure, and an open EGR valve.
Conversation Summary
A 2000 GMC Sonoma 4.3 owner reported a check engine light for a secondary air injection malfunction and a cylinder 2 misfire, plus poor fuel mileage. Replacing the plugs and wires cleared the light for about 500 miles before both codes returned. The expert explained that secondary air comes from the air pump to help the catalytic converter and listed possible misfire causes including a weak coil, lean mixture, dirty injectors, vacuum leaks, a burned exhaust valve, bad fuel, low fuel pressure, and an open EGR valve.
