About one every 4 to 5 months I get the code P0301, #1 cylinder misfire. It almost always sets when the truck is idling. The code clears after about 50 miles and then doesn't return for another 4-5 months. I've replaced the #1 spark plug with no change.
Also I read in the Shop Manual that this code is sometimes thrown for the automatic when it is traveling on a bumpy road and the crank shaft and cam shaft gets off. I do have a long bumpy driveway, but the code doesn't usually come as I'm driving down the drive. There is a slight misfire sound when it is idling.
Any clues as to where to look?
Doug Simmons
Doug Simmons
Mar 11, 2009 at 5:02 AM
