HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
GMC
Sonoma
Engine
MAP Sensor
Location
1998 GMC Sonoma
PAISDAD
MEMBER
1998 GMC SONOMA
1998 GMC Sonoma Automatic
Where is the map sensor located on the GMC Sonoma?
Sunday, April 13th, 2008 AT 12:25 AM
MASTERTECHTIM
MECHANIC
What size engine? Why are you looking for it?
Sunday, April 13th, 2008 AT 7:11 AM
PAISDAD
MEMBER
The engine size is 2.2L sls I need to replace the map senor, acording to code machine
Sunday, April 13th, 2008 AT 10:53 PM
Please
login
or
register
to post a reply.
Related MAP Sensor Location Content
1998 Gmc Sonoma Timing Chain
Engine Mechanical Problem 1998 Gmc Sonoma 4 Cyl Two Wheel Drive Automatic My Sonoma Doesn't Start And We Believe That The Problem Is...
Asked by
nicholai42
1998
GMC SONOMA
1998 Gmc Sonoma Vacuum Lines
My 1998 Fuel Injected Sonoma Had An Extremely Bad Vacum Hose Which Dissapears Into The Drivers Side Wheel Well And Starts At The Fuell...
Asked by
whisperxvi
1 ANSWER
1998
GMC SONOMA
1998 Gmc Sonoma No Power To Starter
Truck Will Start If Jumped From The Starter, But No When Turning The Key In Ignition. Please Help Me.
Asked by
cathycecil
1 ANSWER
1998
GMC SONOMA
Vacuum Line
A Vacuum Line Came Off The Throttle Body And I Can Not Find Where The Other End Goes. I Need A Picture Of Where The Vacuum Lines Go
Asked by
mystyfyr
2 IMAGES
1996
GMC SONOMA
1995 Gmc Sonoma 4.3 Liter Two Wheel Automatic How Does...
I Have Fuel Mix With The Oil
Asked by
slygogetta
1995
GMC SONOMA
VIEW MORE
Code Read Retrieval/Clear Honda
How to Read Codes
Check Engine Light
