1998 GMC Sonoma
BUDDYLUM
  • 1998 GMC SONOMA
Electrical problem
1998 GMC Sonoma 4 cyl Two Wheel Drive Automatic
The ECM fuse blows after I start the truck when I try to accelerate. The fuel pump pressure read low so pump and filter has been replaced. Don't know where to go frem here, any suggestions?
Monday, May 31st, 2010 AT 10:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
This is caused by a short in the wiring. Have you had any electrical work done prior to the fuel pump replacement? If so, start with inspecting wiring there. Is check engine light on?
Monday, May 31st, 2010 AT 1:46 PM
