4WD automatic trans failure
CHAUNCEBOMB
  • GMC SIERRA
1983 GMC sierra, 120k mi, 350 v8- had trans rebuilt 2 yrs ago, has worked fine. I lost all gears while cruising about 40 mph on level road. This was accompanied by a gnarley sound of grinding/spinning noises. I put the vehicle in 4w lo, and it moves, so I drove home very slowly(it was about 20 degrees out and my wife was with me, and we were not dressed for a 5 mi. Walk)is this an internal band/planetary problem? Fluid was not leaking or low.
Monday, March 19th, 2007 AT 10:45 PM
CHAUNCEBOMB
  • 5 POSTS
You should probably just melt your truck into a single ingot of ferrous metal and sell it for the 18 dollars that would be worth. This would allow you to buy at least 3 packs of smokes that would get you through the sticker shock of a new truck that is comparable.
Tuesday, March 20th, 2007 AT 11:40 PM
