engine revved like i was in neutral?
93,600 MILES • V8 • 4WD • AUTOMATIC
JASONEMME
i was driving for about 30 minutes and just pulled away from a stop sign. the truck did not make any weird noises but seemed to be shifting into the next gear when the engine revved like i was in neutral. tried every gear even in 4 wd and had nothing. had towed home on flatbed, not cheap. the seem to lock in park but in any drive or reverse the wheels roll freely. is this a catastrophic failure of the trans.? no unusual noises were heard at time of problem.
Dec 9, 2007 at 6:07 AM
DENNYP
  • 1,824 POSTS
sounds like a possible failure of the sprag gear assembly.Sometimes they will still have reverse and L2.The trans will need to be disassembled to repair.
Dec 9, 2007 at 1:24 PM
  • 55,594 POSTS
Yep, I have seen the input shaft or the transmission break causing the is problem. FYI.
Aug 5, 2024 at 6:24 AM
