2002 GMC Sierra diagnostic codes
2002 GMC SIERRA
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
PECARLEY
my transmission is acting up. when i go to put my car in any position (D, R, P, etc.) it delays in setting it to the gear. the light on my dash which indicates the gear is sometimes not visible. i got a diagnostic reading, but they couldn't find the codes to tell me what was wrong. i have a 2500HD Diesel. the codes they could not find are P0087, P0700, P0872, P0875
Jan 14, 2009 at 4:00 AM
BRIAN 1
  • 1,030 POSTS
try this info:Some customers may comment on one or more of the following conditions.
• The PRNDL display is flashing.
• The engine will not start.
• The "Service Engine Soon" Indicator lamp is illuminated.
• The transmission does not shift properly.
• The vehicle will not move, transmission will not engage.
Cause
Moisture contamination within the Park Neutral Position (PNP) Switch may cause this condition. This is sometimes referred to as the Neutral Start Back-up (NSBU) Switch. On a left turn, water spray from the left front tire is directed directly at this switch. Proper installation of the "Front Shield" and "Rear Shield" are essential for proper repairs.Important: Remember, everything starts with a properly operating Neutral Start Back Up (NSBU) switch. The NSBU switch has been incorporated into what is now called the Park Neutral Position (PNP) switch. If the PNP switch does not provide the proper voltage signal to the module indicating the transmission is in either Park or Neutral, the module will not allow the starter operation. After the engine is started, and the shift lever is moved to either Reverse or one of the drive positions, the range selected portion of the PNP switch portion provides a voltage input to the module as to what range the driver has manually selected for transmission operation. The module then controls pressures, shift points and other transmission functions based on the voltage input received from the range portion of the PNP switch. The list of these conditions does not imply any type of frequency or order. They are random events and may occur in any order.
• DTC P0708, Neutral start/backup (PNP or NSBU) switch
• DTC P0847, Pressure Switch Manifold (PSM)
• DTC P0872, Pressure Switch Manifold (PSM)
• DTC P0875, Pressure Switch Manifold (PSM)
• DTC P1711, Pressure Switch Manifold (PSM)
• DTC P1713, Pressure Switch Manifold (PSM)
• DTC U1000, Serial Data Communications
• Blank PRNDL Display
• Flashing PRNDL Display
• Slow or No Engagement of Automatic Transmission
Blank PRNDL Display
A blank PRNDL display may indicate a condition with the PNP switch and/or one or more of the four signal circuits from the PNP to the TCM.
Pin A, Circuit 771 (BLK/WHT)
Pin B, Circuit 773 (GRA)
Pin C, Circuit 776 (WHT)
Pin D, Circuit 772 (YEL)
Or, a blank PRNDL display may also occur if an out of line condition exists with the Serial Data Circuit (CKT 2470, yellow wire) from the TCM to Splice Pack 205.
A flashing PRNDL display may be the result of incorrect sensor inputs or transmission abuse protection modes being received by the TCM. The following are some of these conditions:
• The transfer case is/was in Neutral.
• The transfer case is/was shifted into Neutral when the vehicle is moving.
• A decrease of the input turbine speed was not detected when the gear selector was moved into any gear.
• A low transmission fluid level.
• A misadjusted PNP/NSBU switch.
• Turbine input speed or output speed sensor failure.
• Failures of the shift solenoids to route the transmission oil to the proper clutch assemblies within the transmission.
• Failures of the transmission clutch packs (C1 or C5 for first gear, C3 or C5 for Reverse).
• Failure to detect proper line pressures when a gear range is selected, which may be the result of normal maintenance such as a transmission fluid change having been completed, or the transmission pan was removed for a filter replacement or other type service.
Transmission abuse protection modes are encountered when a customer performs one of the following types of maneuvers:
• Shifting from Neutral to Drive/Reverse when the engine RPM is greater than 1400 RPM.
• Shifting from Drive to Reverse when the throttle position (TPS) is greater than 25%, such as rocking the vehicle when stuck in an attempt to free the vehicle.
• When the transmission output speed is greater than 300 RPM from attempted changes in direction such as Reverse to Drive, Drive to Reverse or Neutral to Reverse shifts.
When the TCM encounters any one of the above conditions, the TCM will flash the PRNDL and default the transmission to Neutral. A flashing PRNDL indicates something is/was incorrect. The transmission may need the attention of a qualified service technician.
Correction
Disconnect the wiring harness from the PNP switch.
Disconnect the shift linkage/cable from the shift lever at the transmission.
With a wrench keeping the shift lever from rotating, remove the nut from the end of the selector shaft.
Use a file to remove any burrs or raised metal where the selector lever was seated against the shoulder of the selector shaft.
Important: If the old PNP switch will not slide from the selector shaft without the effort, the selector shaft may need to be filed to remove flaring on the end of the selector shaft. This is important, installing the new switch onto a selector shaft that has damage will cause damage to the new PNP switch.
Remove the two bolts that attach the PNP switch and remove the switch by sliding it outward over the selector shaft.
Make sure the selector shaft is in the N (neutral) position (using a wrench on the selector shaft flats, rotate the shaft to its furthest clockwise position and then rotate counterclockwise two detents).
Important: If the new PNP switch will not slide onto the selector shaft easily, the selector shaft may need to be filed to remove flaring on the end of the selector shaft. This is important, installing the new switch onto a selector shaft that has damage will cause damage to the new PNP switch.
Slide the new PNP switch over the selector shaft with the neutral assurance bracket 920 facing outward and maintaining the correct PNP switch orientation to the selector shaft. Install and hand tighten the two PNP switch attaching bolts so that the PNP switch and bracket may be rotated within the adjusting slots with some effort.
While holding the neutral assurance bracket in engagement with the PNP switch, tighten the two bolts that attach the PNP switch to the transmission case.
Tighten
Tighten the bolts to 27 N·m (20 lb ft).
Remove and discard the neutral assurance bracket.
Important: Installation of the front shield and rear shields are important. Without proper installation of the shield, a return repair is probable. Follow all directions as listed on the installation instructions sheet included in the Switch kit, P/N 29540479.
Fit the new shield onto the PNP switch so that it fits securely against the switch. Make sure this is done before reinstalling the shift lever.
Reinstall the shift lever. With a wrench keeping the shift lever from rotating, install the nut on the end of the selector shaft.
Tighten.
Tighten the nut to 24 N·m (18 lb ft).
Connect the wiring harness connectors to the PNP switch.
Attach the selector cable to the lever. Check and adjust if needed.
Go back to step 4 of the Diagnostics and insure the Tech 2 readings match the shift lever positions.
Important: Clear all DTCs before returning the vehicle to the customer.
I've had a couple or these,it's usually the Park Neutral Position switch,on the side of the trans. the part # is 29540479 before you replace any parts check the trans fluid level,it's very important on Allison trans because any low fluid will cause slow engagment or the trans wont move.try these and post back with what you find.
Jan 14, 2009 at 4:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
This is a TSB (Technical Service Bulletin) for your vehicle. Brian1 (above) has posted the details of the TSB.
P0087 -- Fuel Rail Pressure is LOW
P0700 -- TCM MIL Request
P0872 -- Pressure Switch Solenoid "E" Circuit - STUCK CLOSED
P0875 -- Reverse Pressure Switch Circuit Malfunction
Thanks for using 2carpros.com!
Jan 14, 2009 at 4:18 AM
