2000 GMC Sierra Fuel pump didn't fix problem
175,000 MILES • V8 • 2WD • AUTOMATIC
8WAYCANDYMAN
Yesterday my 2000 gmc Sierra started losing power and wouldn't accelerate for about a minute then died completely. I suspected a fuel pump cause it would run on starter fluid and the plugs were sparking and the relay seemed ok. After replacing the pump and filter it still will not run and now the fuel gauge doesn't work. Any ideas?
Apr 5, 2010 at 8:39 AM
INTERNETMECHANIC
  • 700 POSTS
I don't know which fuel system you have? My database showed two possibilities, csfi and sfi, there is a difference. Use a gage and check fuel pressure. Use a noid lite and check for injector pulse.
With engine cranking, check for voltage at fuel pump connector. Gray wire is pump motor voltage, black wire is ground. At present, don't know about your gage issue?
Apr 5, 2010 at 8:56 AM
8WAYCANDYMAN
[quote:f45e514fe1="internetmechanic"]I don't know which fuel system you have? My database showed two possibilities, csfi and sfi, there is a difference. Use a gage and check fuel pressure. Use a noid lite and check for injector pulse.
With engine cranking, check for voltage at fuel pump connector. Gray wire is pump motor voltage, black wire is ground. At present, don't know about your gage issue?[/quote:f45e514fe1]
thanks for the info but I decided to cut my loses and hauled to a shop. Turns out that I left a ground wire disconnected.
Apr 8, 2010 at 1:03 PM
