2000 GMC Sierra Excessive cranking on warm restart
RICHINNM
  • 2000 GMC SIERRA
  • V8
  • 4WD
  • 43,500 MILES
My 2000 GMC Sierra has an issue with warm restarts. Oncwe the engine is warmed up and shut off, it requires 6-8 seconds of cranking to start. Alternatively if I hold the accelerator to the floor while cranking, the engine restarts almost immediately (though it runs a little unevenly for the first 15-20 seconds). Any suggestions?
Thursday, October 15th, 2009 AT 1:58 PM
  • 109,885 POSTS
Has the check engine light come on? It sounds like the temp sensor is bad and causing the engine to flood. Basically, the sensor tells the computer engine temp and outside temp so it knows how rich to make the air fuel mixture at start up.
Also, if the check engine light hasn't come on, I want you to check fuel pump pressure when it is warm. Here is a how to for checking it.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Thursday, October 15th, 2009 AT 9:21 PM
