1995 GMC Sierra van shuts off
CARLBT777
  • 1995 GMC SIERRA
  • V8
  • 4WD
  • 168,173 MILES
When you drive it after awhile it will shut off and you have to wait for awhile for something to cool off then it will drive again for awhile and so on
Monday, May 10th, 2010 AT 6:25 PM
INTERNETMECHANIC
  • 700 POSTS
When the problem occurs, have a helper crank it, while you visuall check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. Try not to get gas on a hot engine. If your still fully obd1 compliant, you can check your own trouble codes.
To check for spark at the plugs, you can carry a known good plug or spark tester in the glove box. Pull spark plug wire, if hot, the autostore sells a plug wire puller. Stick the plug/tester in the spark plug boot, ground metal part of tester to metal part of engine, watch for spark, engine cranking. Intermittent issues are a hassle, something usually fails when there is nobody around to crank the vehicle, while you do testing, that's the way it goes?
Tuesday, May 11th, 2010 AT 11:42 AM
CARLBT777
Thanks for your response, I'll give a try when I got some time and get back to you, but that sound logical
I'll try and get a spark plug tester don't like shocks
Tuesday, May 11th, 2010 AT 12:04 PM
Related General Content
