1995 GMC Sierra tail lights
199,000 MILES • V8 • 4WD • AUTOMATIC
DAN SUMSION
my tail lights do not work. the brake and turn signal lights do work. the front marker lights did not work so I replaced the fuse, this fixed the front markers but not the rear lights. is there another fuse for the rear tail lights or what else could be wrong?
Jul 25, 2009 at 3:33 PM
  • 75,988 POSTS
One thing for sure the ground is good otherwise the other lights will no come on. Check fuse no. 9 20amp in the fuse block lower left side of the instrument panel if okay you have a defective headlight/panel dimmer switch
Good Luck
Jul 25, 2009 at 4:09 PM
