On the hei distributors I've looked at, the single terminals are labeled, bat and tach. The bat terminal is ignition feed, goes hot when you turn on the key, primary voltage to the coil, without that, no spark at the plugs. The tach terminal is signal, you can hook a testlite to it, to check for pulse with engine cranking.
Monday, July 13th, 2009 AT 10:52 AM
