2003 GMC Savana Stalls at Idle
FALKFITNESS
2003 GMC Savana, 90000 mi.
More and more often, whenever I come to a stop or slow down for a turn, the engine will either stall or stutter. When it's idling it also sputters and sometimes stalls out. It's worse with the AC on.
I've had plugs, wires, coils, checked out and short of pulling ever injector out and cleaning for 200 a piece, I'm lost. Help please.
Aug 14, 2006 at 11:45 AM
MIKEYBDMAN
  • 623 POSTS
[quote:51fab6d294="falkfitness"]2003 GMC Savana, 90000 mi.
I've had plugs, wires, coils, checked out and short of pulling ever injector out and cleaning for 200 a piece, I'm lost. Help please.[/quote:51fab6d294]
Almost sounds like a bad MAP sensor. Probably going to need to put it on a diagnostic machine and see what is going on.
Aug 14, 2006 at 12:21 PM
Suggested Repair
Scan the vehicle with a diagnostic machine and test the MAP sensor, which may be failing and causing the stalling and idle stumble.
Conversation Summary
A 2003 GMC Savana with 90,000 miles increasingly stalls or stutters when stopping or slowing for a turn, and sputters or stalls at idle, worse with the AC on. Plugs, wires, and coils were already checked. The expert said it sounds like a bad MAP sensor and recommended diagnostic scanning to see what is going on.
