hi-this van has hydraulic assisted brakes from th epower stg
the stg shaft broke and was replaced
coming off the expressway applying brakes the stg shaft broke again!What is going on here?
Saturday, December 27th, 2008 AT 7:52 AM
DENNYP
MECHANIC
Where is the steering shaft breaking? Are you noticing any difficulty turning the wheel before this happens? Are there any strange noises?
SPONSORED LINKS
Saturday, December 27th, 2008 AT 8:24 PM
SMAX
MEMBER
Didn t hear noises
shaft breaks inside the p/stg pump by the gears inside
fluid then leaks out of seal
cheers
Sunday, December 28th, 2008 AT 6:07 AM
SMAX
MEMBER
Still awaiting reply
thanx
Monday, December 29th, 2008 AT 7:36 AM
DENNYP
MECHANIC
The power steering pump shaft is a common problem. You need to make sure you are installing the pulley properly. Do NOT hammer the pulley on. Only use a pulley installer. Make sure the pulley is pressed on flush with the pump shaft. There should not be any of the pulley showing past the pump shaft.
Tuesday, December 30th, 2008 AT 3:56 PM
SMAX
MEMBER
Hi
i already changed the pump on saturday as never heard back from u
please refund the $5 this time
thanx
SPONSORED LINKS
Tuesday, December 30th, 2008 AT 9:22 PM
THIS IS MIKE
MECHANIC
We will be glad to refund your donation. We are sorry we could not help you.
