1999 GMC Safari 99 Gmc Safari fuel pump system...
1999 GMC SAFARI
105,000 MILES • 6 CYL • 4WD • AUTOMATIC
HARRY2
Preparing to change the fuel pump and noticed a box? beside the fuel TANK that has one line running to the pump. I have an idea what this device is. I think it is the fuel pump pressure regulator. CORRECT? Is this attached to the return line? Is there some kind of a test I can do that will tell me if it is working? I checked the fuse and changed the pump relay. I hear no pump running noise nor is there any pressure when I took off lines to change the filter. I'm assuming the pump is bad and bought one. I don't want to change the pump if there could be another reason why it's not working.. That device I described above concerns me.. How would I know if it's the cause..
Any info would be appreciated, Thanks...
Harry2
4/29 Thanks. Is it your opinion that the problem is just the fuel pump??
Apr 27, 2010 at 11:20 AM
RACEFAN966
  • 5,029 POSTS
No it is not the regulator it, the regulator is under the upper plunem ontop of the fuel injection system. That is part of the smog system, the fuel vapor canister, this captures the vapors coming from the tank and then when it is triggered it allows the fumes to go back to the intake to be burned. Sorry you didn't get the answer quicker but I just saw the question myself. Anyway if there is anything more I can do let me know.
Apr 29, 2010 at 2:25 AM
