1992 GMC Safari Pulling to left
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
SIMBARALPH
I just bought this van and it's pulling to the left I did all new front end check the ball joint's and it is still pulling to left I would love if u could help with this problem.
Thank you
May 3, 2008 at 8:15 AM
JESUS BERRIOS
Thats sound to me that it needs a wheel alignment, alot of times ball joints and tie rods are fine but your alignment can be off a bit i would take it to get alligned somewhere reputalble and they will be able to tell you if there is something wrong. If there's a sears near you with a tire shop they usually do allignment they're pretty good they have a digital system that they do it with. I hope that this info helps you out.
May 20, 2008 at 10:58 AM
