1987 GMC S15 occaisional buzz saw noise while dring down th
1987 GMC S15
14,800 MILES • 6 CYL • 4WD • MANUAL
SMERLO
My 87 s-15 4x4 2.8 makes this buzz saw noise from the front every 5 to 10 minutes while I am going down the road even on the straight roads and in 2 wheel drive. This noise has continued the same even after I replaced both front wheel bearings, and starter. I have no idea what to look at next.
May 3, 2009 at 9:08 AM
SWILLIAMS
  • CAR REPAIR CONTRIBUTOR
  • 597 POSTS
Disconnect the 4X4 actuator hose and plug the hose. See if the noise stops. If it does then change the 4X4 vacuum switch on the transfer case. It is leaking vacuum enough that it is pulling the axle disconnect partially in. What you're hearing is the disconnect collar trying to engage.
Jun 28, 2009 at 6:29 PM
