1998 Chevrolet Camaro Cold Start Tick
GMC
BMOORE35
1998 Camaro, 85000 miles, 3800 V-6 - When I cold start the car, there is a pretty loud clicking sound from the engine. Kinda like it is low on oil. However, oil level is fine (recently changed). Oil pressure is always good. After a couple of minutes, the noise stops and the car runs great. :?:
May 2, 2006 at 3:35 AM
LOSONE
  • 1,616 POSTS
You have a temperamental hydraulic valve lifter. Go to the parts store and buy a pint of Rislone. It is an old line mechanics helper, like me the old mechanic.
It will dissipate in the engine and you don't have to remove any oil. I would suggest a fresh oil change with it.
May 2, 2006 at 4:44 AM
Suggested Repair
Treat a sticky hydraulic valve lifter by adding a pint of Rislone during a fresh oil change. It can be added without draining oil, but a fresh oil change is recommended.
Conversation Summary
A 1998 Camaro with a 3800 V6 ticks loudly on cold start, similar to low oil, then quiets after a couple of minutes and runs well. Oil level and pressure are good. The expert attributes the noise to a temperamental hydraulic valve lifter and recommends adding Rislone, preferably with a fresh oil change.
