1995 Chevy S10 Starter Hard to Remove
1995 GMC
CBRUNNER82
I have a 95 Chevy S10 v6 4.3 vin model Z. I know the basics of car repair but I unfortunatlly have never changed a starter, but some buddies of mine have and offered to help to save me some money. Once we got under the truck we realized this was not as easy as first expected. The starter seems to be in there very tight. We removed the manafold or (cover) around the fly wheel and that gave us a bit more room but now it seems the wires are taught and it is not allowing us to pull the starter out. I was hoping that someone might know something we don't already know, possibly something else needs to be removed. Thank you any suggestions would be helpful
Chad
Apr 12, 2006 at 2:26 AM
LOSONE
  • 1,616 POSTS
Make sure the battery is disconnected. Locate the harness that connects to the starter and follow it up looking for connections that secure it to the engine and fire wall.Do the same for the battery cable. Disconnect them and it should give you enough room to move the starter far enough to disconnect the wires.
Apr 12, 2006 at 5:09 AM
Suggested Repair
Disconnect the battery. Follow the starter harness and battery cable up to the engine and firewall, disconnect the clips securing them, then move the starter enough to disconnect the wires and remove it.
Conversation Summary
The owner of a 1995 Chevy S10 with a 4.3 V6 could not pull the starter out after removing the flywheel cover because the wires were too tight. The expert advised disconnecting the battery, tracing the starter harness and battery cable, and releasing the connections that secure them to the engine and firewall so the starter can be moved far enough to disconnect the wires.
