2003 Other GMC Models
1956RUST
  • 2003 GMC
  • 4 CYL
  • MANUAL
  • 175,000 MILES
AT ANY SPEED IT FEELS LIKE YOU ARE STARTING OFF IN HIGH GEAR, GIVE IT THE GAS IT STARTS JERKING, CHANGED PLUGS AND WIRES, IS IT POSSIBLE THAT IT COULD BE BAD CONNECTIONS AT THE FUELPUMP HARNESS OR A VACUME LEAK, SOME SAY THAT THE HARNESS CONNECTIONS AT THE FUELPUMP GO BAD EXPECIALY THE GROUND.
Wednesday, November 18th, 2009 AT 7:31 PM
PEAR69
  • 1,482 POSTS
Any of those things are possible. The grounds for the fuel pump are an issue, as well as the fuel pump connector.
Is the check engine light on? Was the fuel pump changed recently / or / ever? A vacuum leak is obvious.
Thursday, November 19th, 2009 AT 1:44 AM
