1986 GMC pich up fuel pump.
1986 GMC
JCHAPPIE
I have a 1986 GMC pick up with 120,000 miles, F/I with a 305.I do not have 12vdc to the pump, I checked the wire from the ECM to the relay with ignition on and have no voltage, I do have battery voltage on the relay. Is there a sensor that would keep the ECM from sending the voltage, or anything else to check? Is it possible to bypass the ECM and power the pump from elswhere?
Jun 22, 2007 at 7:01 AM
MICKEY-D
  • CERTIFIED EXPERT
  • 304 POSTS
I assume the relay is good. You should be able to power it up from any key on power wire that maintains power while cranking.
Jan 7, 2010 at 3:04 PM
