Shuttering Jimmy
GMC JIMMY
SUMMER
  • 13 POSTS
I took my 1990 GMC Jimmy 8000 Ft above sea level. It really did nto like that. Now it shutters constantly and smells of gas. Sometimes it seems that it is not taking in the gas well. Did i mess up my fuel pump? :cry:
Jan 12, 2006 at 8:28 AM
2CARPRO JACK
  • 11,533 POSTS
maybe some bad gas
Jan 12, 2006 at 9:41 AM
HEARTS88
Check your EGR valve. If I remember correctly, you will have an Electronic EGR. Not cheap to replace, have a mechanic check it out.
Regards.
Hearts88
Jan 12, 2006 at 10:27 AM
HEARTS88
On second thought... That year may not have the Electronic EGR. But check...if you do, it could be that. I had a'93 that was shuttering and stuff. Would sound like it was bogging out.
Had to replace the Electronic EGR Valve.
Regards.
Hearts88
Jan 12, 2006 at 10:29 AM
SUMMER
  • 13 POSTS
Thank you i will look into that.... :)
Jan 13, 2006 at 3:27 AM
SUMMER
  • 13 POSTS
BAD GAS THO??? I have refueled serveral times.....another thing i just noticed tho is, my tail pipe is coverd in black. only on the inside.
Jan 13, 2006 at 3:48 AM
HEARTS88
Summer,
Black on your tailpipe... hmm... does it come off like soot?
Could be carbon... Did you check into the EGR valve.
I know when I had my truck, and removed the Electronic EGR valve it was covered in soot like crud. my tail pipe was the same way.
Let me know how you make out.
Hearts88
Jan 14, 2006 at 1:32 PM
