jimmy 4x4
GMC JIMMY
SC
I have a 1996 jimmy that will not shift into 4 wheel drive. It has an electronic switch on the dash. It worked fine one day and the next it would not. All the lights flashed a couple times and then it stays in 2 wheel. After trying a few times it finally went into 4low. Now when pushing either 4low or high nothing happens at all. The lights don't come on or even flash at all. The only light that comes on is the 2wheel drive light. I tried a new switch but that was not the problem. Any suggestions?
Jan 17, 2006 at 1:59 PM
PULSTI
  • 28 POSTS
are you shutting down your vehical first, having it runnung while switching can ruin it
Jan 17, 2006 at 2:05 PM
