1993 GMC Jimmy Intermittent No-Start
KEVINNESLUND
Is it possible for a bad fuel pump to cause a vehicle to not start? My GMC Jimmy (1993 with 177,500 miles) will start intermittently. For example, it will start and run on some occasions, but, after turning it off, if I go back out only moments later, and sometimes even a couple hours later, it cranks just fine but just refuses to start. I'm hearing from different people it's probably a bad fuel pump that needs replacing due to a possibly bad pulse dampener which is located on the pump assembly. Is that possible for a bad fuel pump to not allow the vehicle to start?
Thanks,
May 4, 2007 at 2:29 AM
BACKYARDMECHANIC
  • 337 POSTS
It is possible for the car not to start from a fautly fuel pump. However they usually are not intermittenly bad. Before you start changing out parts you need to determine if it is a fuel problem or not. What you described could be cause by a number of things besides the fuel pump. It could be a fuel problem or ignition problem, but you won't know unless you make some test.The next time the car won't start check to see if you have fuel and spark. Then you will know which direction to go in and save time and money. Good luck
May 4, 2007 at 5:52 AM
Suggested Repair
Before replacing the fuel pump, the next time the Jimmy cranks but will not start, check for fuel and spark to determine whether the problem is fuel delivery or ignition.
Conversation Summary
The owner of a 1993 GMC Jimmy with intermittent no-start symptoms asked whether a bad fuel pump or pulse dampener could keep it from starting. The expert said a faulty pump can cause a no-start but is usually not intermittent, and advised checking for fuel and spark before replacing parts.
