1996 GMC Jimmy Brakes Dragging
FNSIDSMOM
I recently replaced the power brake booster in my 1996 GMC Jimmy and now the front brakes feel like they are constantly engaged, they sound like metal rubbing together and smell after driving the car. The steering wheel shakes and it feels like I have a flat tire. I greased the caliper pistons and replaced the brake pads 3 days ago and the pads already need to be replaced. Any suggestions? The car has 147,400 miles on it. Oh and the parking brake light is always on.
Aug 14, 2006 at 3:28 AM
BURRBRIAN
  • 158 POSTS
You might want to check and see if perhaps the parking brake is just slightly engaged. The release might seem like it's off but check the cables running to the wheels themselves. Also might want to pull a wheel and check the action down there on the cable. It's possible that it's sticking and just barely engaged. Had this happen on girlfriends 97 ford and cost us $1000 to redo system. But definetly find your problem before driving much or you could have the same situation. Hate to see that happen!! Good luck 8)
Aug 15, 2006 at 12:33 AM
Suggested Repair
Inspect the parking brake cables at the wheels. The release may appear off while a cable is sticking and keeping the brake slightly applied. Confirm the cause before driving further to avoid rapid brake damage.
Conversation Summary
The owner of a 1996 GMC Jimmy says the front brakes feel constantly engaged after a power brake booster replacement, with metal rubbing, a burning smell, steering-wheel shake, and rapid pad wear. The parking brake light stays on. The expert suggests checking whether a parking brake cable is sticking and slightly applied at a wheel, and advises finding the cause before driving much farther.
