2000 GMC Jimmy ABS Light and Skidding
TESS_I_AM
I own a 2000 GMC Jimmy V6, 86,000 miles and about every 2-3 months as I'm driving I feel like the car is skidding or sliding when I try to stop. Right after that, the ABS light is on. I take it to the repair shop, they say it is a sensor and put a new one in. Since I have had the vehicle this has occurred 12 times. A bit too much, don't you think? Should I switch repair shops? Should I get rid of the vehicle, is this always going to happen? Thankfully, the time between sensors is so brief, most of the time they are still under warranty, but it's the 1-2 days without my car that is difficult
Sep 5, 2007 at 5:40 AM
SERVICE WRITER
  • 9,123 POSTS
I think you need to have a talk with the owner of the shop. You need to firmly explain how your trying to be loyal, but are continually being inconveineced by faulty parts assuming the diagnosis is correct. Be nice, but be firm. It may be a harness problem, not the sensor...may want to suggest an OEM one.
Sep 11, 2007 at 12:57 AM
Suggested Repair
Speak firmly but politely with the shop owner about repeated sensor replacements. Suspect a wiring harness fault rather than the sensor itself, and request an OEM sensor if a sensor is replaced.
Conversation Summary
The owner of a 2000 GMC Jimmy reports a skidding or sliding sensation when stopping about every two to three months, followed by the ABS light. Shops have replaced a sensor 12 times, often under warranty, causing repeated downtime. The expert advises discussing the pattern with the shop owner and suggests the cause may be a harness problem rather than the sensor, with an OEM sensor preferred if replacement is needed.
